Bryski Posted March 9, 2011 Share Posted March 9, 2011 I have a header on a wordpress theme that i want to edit. the theme is: http://worldoffishin...reen/header.png I am very new to this, so noddy instructions would be great. On the left hand side of the header there is an oval with the words Fishing Charters, i want to change that to say World of Fishing. If anyone could tell me how to do that i would be very grateful. Many thanks in advance Quote Link to comment Share on other sites More sharing options...
barbieq25 Posted March 9, 2011 Share Posted March 9, 2011 My thinking is to put a new oval over the top. So you would open the image & create a new layer. On the new layer, select the ellipse using the ellipse tool & you will probably have to move the selection a bit. Zoom in as far as you can so that you can be sure to get it spot on. Then with the selection still active run a gradient with white & a very pale grey. I think I started at the bottom of the ellipse. If it isn't right then press CTRL + Z to undo & do it the opposite way. Make sure you keep the selection active. Create a new layer. Go to Effects - Selection - Outline Selection & choose white at 10. Create a new layer & type the text you want (can't help you with the font). Colour at this stage doesn't matter. Select the text by selecting the Magic Wand & set it to global, @ 50% (default), anywhere outside of the text. Press CTRL + I to invert the selection. Then do a gradient with the colours of you choice. New layer & press CTRL + I to invert selection. Go to Effects - Selection - Outline Selection & choose white at whatever you need but also check the "Preserve Canvas Edge". Not sure if you wanted the grey text too but I am sure you will find a bevelled text tute here somewhere. At this stage I would Gaussian Blur @ 1 or 2 each layer but the original image. Then merge the text & the outline layer & deselect the text. On the merged text layer run Effects - Object - Drop Shadow. Adjust the setting to your needs & remember that you can also adjust the opacity. Someone else may have a better or quicker way but I hope this gives you a start at least. Quote Knowledge is no burden to carry. April Jones, 2012 Gallery My DA Gallery Link to comment Share on other sites More sharing options...
