Flipper Posted December 31, 2010 Share Posted December 31, 2010 I have several pictures that when I shrunk them they develop a "ring" of sami-transparency. I was wondering how I can convert those to their full opacity. I found using curves+ helped but also converted my full alpha to black and thus caused another step to remove that. Fortunately my image was eassy, I can see how som images wouldn;t be easy in the future. to clarify... alpha = transparency/opacity? full alpha (can not be seen) is value 0? fully opaque value = 255? so for my application if alpha value <255 and >0 then alpha value = 255 Quote Link to comment Share on other sites More sharing options...
Sarkut Posted December 31, 2010 Share Posted December 31, 2010 The Transparency plugin is part of the BoltBait plugin pack. Once installed, it will show in the Adjustments menu. Move the slider to the right, towards Opaque. Quote Link to comment Share on other sites More sharing options...
Flipper Posted December 31, 2010 Author Share Posted December 31, 2010 Thanks!!!!!! Quote Link to comment Share on other sites More sharing options...
