vcoder Posted December 9, 2009 Share Posted December 9, 2009 I look the forum but looks like I have a different installation problem. I have .net 3.5 (and SP1 as well) installed. OS - Vista Business. I used "Windows Installer Clean Up". But it doesn't help. I got following error: --------------------------- (null) --------------------------- System.IO.FileNotFoundException: Could not load file or assembly 'WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified. File name: 'WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' at PaintDotNet.PdnResources.LoadImage(Stream input) at PaintDotNet.PdnResources.GetImage(String fileName) in D:\src\pdn\paintdotnet\src\Resources\PdnResources.cs:line 322 at PaintDotNet.PdnResources.PdnImageResource.Load() in D:\src\pdn\paintdotnet\src\Resources\PdnResources.cs:line 337 at PaintDotNet.Resource`1.get_Reference() in D:\src\pdn\paintdotnet\src\Base\Resource`1.cs:line 28 at PaintDotNet.Controls.PdnBanner..ctor() in D:\src\pdn\paintdotnet\src\Core\Controls\PdnBanner.cs:line 34 at PaintDotNet.Setup.SetupWizard.InitializeComponent() in D:\src\pdn\paintdotnet\src\SetupFrontEnd\SetupWizard.cs:line 695 at PaintDotNet.Setup.SetupWizard..ctor() in D:\src\pdn\paintdotnet\src\SetupFrontEnd\SetupWizard.cs:line 411 at PaintDotNet.Setup.SetupWizard.MainImpl(String[] args) in D:\src\pdn\paintdotnet\src\SetupFrontEnd\SetupWizard.cs:line 1038 at PaintDotNet.Setup.SetupWizard.Main(String[] args) in D:\src\pdn\paintdotnet\src\SetupFrontEnd\SetupWizard.cs:line 943 === Pre-bind state information === LOG: User = Dmitriy-PC\Dmitriy LOG: DisplayName = WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 (Fully-specified) LOG: Appbase = file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/ LOG: Initial PrivatePath = NULL Calling assembly : PaintDotNet.Resources, Version=3.51.3610.35022, Culture=neutral, PublicKeyToken=null. === LOG: This bind starts in default load context. LOG: Using application configuration file: C:\Users\Dmitriy\AppData\Local\Temp\PdnSetup\SetupFrontEnd.exe.Config LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v2.0.50727\config\machine.config. LOG: Post-policy reference: WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/WindowsBase.DLL. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/WindowsBase/WindowsBase.DLL. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/Native.x86/WindowsBase.DLL. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/Native.x86/WindowsBase/WindowsBase.DLL. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/Native.x64/WindowsBase.DLL. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/Native.x64/WindowsBase/WindowsBase.DLL. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/WindowsBase.EXE. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/WindowsBase/WindowsBase.EXE. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/Native.x86/WindowsBase.EXE. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/Native.x86/WindowsBase/WindowsBase.EXE. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/Native.x64/WindowsBase.EXE. LOG: Attempting download of new URL file:///C:/Users/Dmitriy/AppData/Local/Temp/PdnSetup/Native.x64/WindowsBase/WindowsBase.EXE. --------------------------- OK --------------------------- Any suggestions? Quote Link to comment Share on other sites More sharing options...
vcoder Posted December 9, 2009 Author Share Posted December 9, 2009 BTW, PDN - latest version 3.5.1 I tried to repair .net 3.5 & .net 3.5sp1 It doesn't help Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 11, 2009 Share Posted December 11, 2009 For some reason, it looks like you don't have .NET 3.0 installed (yes, .NET 3.0). I've seen this in some crash logs that've been sent to me. I've not been able to reproduce this myself, but you'll have to find some way to completely repair / reinstall / fix .NET. Start by getting rid of .NET 3.5 SP1, then try and fix .NET 3.0 (I don't know how), then install .NET 3.5 SP1 / Paint.NET 3.5.1. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
alesx Posted December 24, 2009 Share Posted December 24, 2009 vcoder, I was having the same issue as you, but I think I've found a solution. You need to do this: Start Orb >> Control Panel >> Programs and Features >> 'Turn Windows features on or off' and make sure 'XPS viewer' under the 'Microsoft .NET Framework 3.0' is turned on (don't ask me why!). Click OK, allow the changes to be made and you should be able to run the installer and program. :wink: Season's Greetings, Alex Quote Link to comment Share on other sites More sharing options...
vcoder Posted December 28, 2009 Author Share Posted December 28, 2009 I solved the issue. I found utility which completely uninstall .net After that I reinstall .net Thank you for your reply. Quote Link to comment Share on other sites More sharing options...
comaxauto Posted July 7, 2010 Share Posted July 7, 2010 I was having the same issue as you, but I think I've found a solution. You need to do this: Start Orb >> Control Panel >> Programs and Features >> 'Turn Windows features on or off' and make sure 'XPS viewer' under the 'Microsoft .NET Framework 3.0' is turned on (don't ask me why!). Click OK, allow the changes to be made and you should be able to run the installer and program. Running Vista Home Basic SP2, I was getting the "System.IO.FileNotFoundException: Could not load file or assembly 'WindowsBase, Version=3.0.0.0..." error message when trying to install Paint.NET 3.5.5. I tried performing a Repair on .NET Framework 3.5 SP1, but that didn't help. A quick Google search found this thread, I turned on the XPS Viewer feature, and the Paint.NET 3.5.5 install went smoothly. Thanks to alesx for that solution! Quote Link to comment Share on other sites More sharing options...
