Taylor Posted August 11, 2006 Share Posted August 11, 2006 Ok so im using the flooding tool. Say if i make a circle, with the circle tool, and use the floding tool to fill it in with black. Instead of just the circle colouring in, the whole image colours in (or the part of the image that is selected with the cutting tool.) It also does the same with hte magic wand! can someone please help me fix this problem Quote Link to comment Share on other sites More sharing options...
trickman Posted August 11, 2006 Share Posted August 11, 2006 ?! it doesn't happen to me... Quote Link to comment Share on other sites More sharing options...
Taylor Posted August 11, 2006 Author Share Posted August 11, 2006 ?! it doesn't happen to me...i asked for help not saying it doesnt happen to youi obviously did something or theres a bug. so someone please help. Quote Link to comment Share on other sites More sharing options...
trickman Posted August 11, 2006 Share Posted August 11, 2006 Wait, did you use the circle TOOL or the circle SELECTION tool? If you used the circle TOOL, check if the tolerance is at 100% or near there. Quote Link to comment Share on other sites More sharing options...
Taylor Posted August 11, 2006 Author Share Posted August 11, 2006 ok here are the images of whats happening http://img147.imageshack.us/img147/6860/onqu6.png this is the result http://img113.imageshack.us/img113/9408/twte8.png Quote Link to comment Share on other sites More sharing options...
trickman Posted August 11, 2006 Share Posted August 11, 2006 Tolerance... http://paintdotnet.12.forumer.com/viewtopic.php?t=1649 Quote Link to comment Share on other sites More sharing options...
RaveN Posted August 11, 2006 Share Posted August 11, 2006 Yeah, set your tolerance down a lot... I set it around 25-0 Same thing happened to me, just gotta play around with it. Quote Link to comment Share on other sites More sharing options...
