powelli Posted July 27, 2009 Share Posted July 27, 2009 Hi, I have been using paint.net for a while now and thinks its brill. I also didnt relise how good it was until I started reading post on this fourm, as you guys seem to the pros maybe you could help me with somet. I am doing some product images with a light box, it has a blue backgorund for chrome key editing. I have downn loaded the chrome key exten from here and it works brill. The only problem is the my prodcuts are very colourful so when I use the chrome key ext, it also take out the blue parts on my products. I assume this can be sorted using layers but havent got there yet. would anyone be so kind and explain how I do this,, :oops: ta Owain Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted July 27, 2009 Share Posted July 27, 2009 Duplicate the layer before chroma-keying it and have the layer being keyed below the other copy. After running the plugin, then simply the areas from the top layer which contain the blue you want to key (as well as the non-key area) but has no red-herrings. Quote Link to comment Share on other sites More sharing options...
powelli Posted July 27, 2009 Author Share Posted July 27, 2009 Hi, thanks not sure what you mean by this though "then simply the areas from the top layer which contain the blue you want to key (as well as the non-key area) but has no red-herrings." :oops: Quote Link to comment Share on other sites More sharing options...
