How to place background in animated gif
I have an animated gif.
Now I would like to place a background to the animated gif.
Can anyone guide in a stepwise manner how to do it in paint.net.
thanks.
Example attached shows one animated gif and a human face to be used as background.
17113_156633ad28ea82b350ad516840b6776f
17113_f10f0d3779853ffc7845a1793db99f62
You'd need to break the gif image down into it's individual frames first, and save each individual frames as it's own file.
I use Click Here to do this task.
I looked and the spider gif is 16 frames
Then, open your background image, and load frame 1 into a layer above it, and merge down, and save as a new image.
Then, open your background image, and load frame 2 into a layer above it, and merge down, and save as a new image.
Then, open your background image, and load frame 3 into a layer above it, and merge down, and save as a new image.
Then, open your background image, and load frame 16 into a layer above it, and merge down, and save as a new image.
Then create your gif file using the individual images you created with the spider running all over her face.
Refer to this tutorial for help
