KakeX Posted July 10, 2009 Share Posted July 10, 2009 When i try install paint.net comes error in middle of install: a network error occurred while attempting to read from file... Could you guys help me out :?: Quote Link to comment Share on other sites More sharing options...
RHoward Posted July 10, 2009 Share Posted July 10, 2009 you might have a bad copy of the program...I downloaded two copies of the program...the first one wouldn't install completley. The second one worked perfectly. Quote Link to comment Share on other sites More sharing options...
HITMAN-X- Posted July 10, 2009 Share Posted July 10, 2009 Is Paint.NET installed local on your computer or on a network drive ? If your trying to run Paint.NET from a network drive, it wont work. Paint.NET must be installed on the computer you are using. The reason for this is the .NET Framework from my understanding. Quote DEXTUT.COM Link to comment Share on other sites More sharing options...
KakeX Posted July 11, 2009 Author Share Posted July 11, 2009 thx i get it fixed... Quote Link to comment Share on other sites More sharing options...
