blardjosh Posted April 10, 2009 Share Posted April 10, 2009 Okay, here is what happened, a couple weeks ago, Paint.Net kept crashing, and so I thought maybe reinstalling it would solve the problem, and then I uninstalled the previous copy I had, then downloaded the new one, and proceeded onto installation, everything goes fine for a while, then this happens: The error details are: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IO.IOException: The file or directory is corrupted and unreadable. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.Directory.InternalGetFileDirectoryNames(String path, String userPathOriginal, String searchPattern, Boolean includeFiles, Boolean includeDirs, SearchOption searchOption) at System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption) at System.IO.Directory.GetFiles(String path, String searchPattern) at PaintDotNet.SystemLayer.FileSystem..cctor() ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- SetupFrontEnd Assembly Version: 3.36.3158.38067 Win32 Version: 3.36.3158.38067 CodeBase: file:///C:/Users/WarMachine/AppData/Local/Temp/PdnSetup/SetupFrontEnd.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- PaintDotNet.SystemLayer Assembly Version: 3.36.3158.38062 Win32 Version: 3.36.3158.38062 CodeBase: file:///C:/Users/WarMachine/AppData/Local/Temp/PdnSetup/PaintDotNet.SystemLayer.DLL ---------------------------------------- PaintDotNet.Base Assembly Version: 3.36.3158.38062 Win32 Version: 3.36.3158.38062 CodeBase: file:///C:/Users/WarMachine/AppData/Local/Temp/PdnSetup/PaintDotNet.Base.DLL ---------------------------------------- PaintDotNet.Resources Assembly Version: 3.36.3158.38063 Win32 Version: 3.36.3158.38063 CodeBase: file:///C:/Users/WarMachine/AppData/Local/Temp/PdnSetup/PaintDotNet.Resources.DLL ---------------------------------------- PaintDotNet.Core Assembly Version: 3.36.3158.38063 Win32 Version: 3.36.3158.38063 CodeBase: file:///C:/Users/WarMachine/AppData/Local/Temp/PdnSetup/PaintDotNet.Core.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. Can someone help me? Edit: I think I cleared the correct temp folder. Quote Link to comment Share on other sites More sharing options...
SP-Stevo- Posted April 10, 2009 Share Posted April 10, 2009 Try changing the directory of the place your installing to. e.g. Instead of installing to C:\Program Files\Paint.NET, change the name maybe or delete the folder and all of it's contents at C:\Program Files\Paint.NET, hope this helps! -Stevo Quote Link to comment Share on other sites More sharing options...
blardjosh Posted April 11, 2009 Author Share Posted April 11, 2009 I'm fairly sure I tried that, but I will try it again when I get back home, but can anyone else supply some more help? And by the way I think 3.36 is the newest, but if it isn't please tell me. Quote Link to comment Share on other sites More sharing options...
blardjosh Posted April 11, 2009 Author Share Posted April 11, 2009 Okay, I found the solution! If anyone else has the same problem, I will post the solution I came up with for it may be their problem too. Since it said the directory was corrupt, I tried all the things I could think of for the directory, but what made it work was, I went to my C:\Users\(USERNAME)\Appdata\Local, and after I went there, I tried deleting the Paint.Net folder that was there, it said I couldn't delete the directory because it was corrupt, so I just renamed it, and now it works like a charm I hope someone will find this solution helpful in the future. Quote Link to comment Share on other sites More sharing options...
