Annihilannic Posted February 22, 2009 Share Posted February 22, 2009 Firstly, Paint.NET is awesome, finally I can throw away all those other horrible bloated photo editors, mentioning no names. Alright, shmoozing over; I have one slightly irritating problem though. When opening multiple files (and occasionally individual ones), either via drag and drop or File | Open | (ctrl-select), the software pauses sometimes for 5-10 seconds as though some kind of background garbage collection is going on or something. Is this expected behaviour? I would guesstimate that it happens for 1 in every 3 file opens, and is more apparently when opening many. I use PDN mainly for resizing images, so often do batches of them, so the problem is readily apparent. I'm running v3.36 under Windows XP Home SP3, and would be happy to try any tests or obtain any debugging info if required (given instructions). I notice a similar report here, although the symptoms differ: http://paintdotnet.forumer.com/viewtopic.php?f=10&t=22476&view=previous. It mentions another thread relating to drag-n-drop, but I couldn't find the original thread. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 22, 2009 Share Posted February 22, 2009 My psychic powers tell me you're using a single core CPU without HyperThreading. This is fixed for the next release, v3.5. http://blog.getpaint.net/2008/09/11/pai ... humbnails/ Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Annihilannic Posted February 23, 2009 Author Share Posted February 23, 2009 The psychic powers are strong in this one! 8) Looking forward to the next release. Quote Link to comment Share on other sites More sharing options...
Annihilannic Posted November 9, 2009 Author Share Posted November 9, 2009 Just wanted to say thanks for fixing that, works perfectly in the new version! Quote Link to comment Share on other sites More sharing options...
