im2foolish4u37 Posted February 14, 2009 Share Posted February 14, 2009 When I try to reinstall Paint.NET (because it got deleted), it tells me "A network error occurred while attempting to read from this file: C:\Program Files\Paint.Net\Staging\PaintDotNet_1399229206.msi" I've tried downloading Windows Installer CleanUp Utility, but when I run THAT, it tells me: Script: C:\DOCUME~1\DADKID~1.000\LOCALS~1\Temp\IXP000.TMP\StartMsi.vbis Line: 1 Char: 1 Error: ActiveX component can't create object: 'Scripting.FilySystemObject' Code: 800A01AD Source: Microsoft VBScript runtime error is there any hope for me to be able to use Paint.NET again?? Quote Link to comment Share on other sites More sharing options...
delong18 Posted February 19, 2009 Share Posted February 19, 2009 Try running the disk cleanup utility and then run the install again. Quote Link to comment Share on other sites More sharing options...
im2foolish4u37 Posted March 8, 2009 Author Share Posted March 8, 2009 it doesn't work for my computer Quote Link to comment Share on other sites More sharing options...
Myrddin Posted March 8, 2009 Share Posted March 8, 2009 Try repairing or reinstalling your .NET Framework. You can repair from Add / Remove Programs in XP or Programs and Features in Vista. Also, details on how your Paint.NET was originally 'deleted' might help - something might be lingering that shouldn't be. Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
im2foolish4u37 Posted March 8, 2009 Author Share Posted March 8, 2009 well i was uninstalling an old game, and the uninstaller messed up and started deleting the whole directory, instead of just the folder of the game, and the directory had the PDN system folder Quote Link to comment Share on other sites More sharing options...
Myrddin Posted March 8, 2009 Share Posted March 8, 2009 Ah, okay. These accidents happen, don't worry. Has repairing/reinstalling the .NET Framework worked? You can reinstall Paint.NET afterwards to make sure. Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
Bob Posted March 8, 2009 Share Posted March 8, 2009 Go to Start > Run... and type this : wscript -regserver Hit OK. Seen here : http://support.microsoft.com/default.aspx/kb/311269 Quote No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
