Mikkel Minor Posted December 19, 2008 Share Posted December 19, 2008 I'm a newb to this, so please bear with me. I'm looking to create a several pictures like this one: With the round edges, the thin colored borderline frame and all of them in the same size. I hope it it won't be to complicated and any help is most welcome. Best wishes Mikkel Quote Link to comment Share on other sites More sharing options...
ZizOiz Posted December 19, 2008 Share Posted December 19, 2008 there are two ways of doing that that I can think of. needed plugins are in red, helpful plugins are in dark red You can locate them by searching in the handy search box! First way, quicker but the rounded corners are always going to be the same size. And the border will be aliased. make a new layerselect rounded rectangle draw tooldraw over the portion of you picture that you want to be in the rounded rectangle pictureselect the magic wand select toolusing the magic wand, select the rounded rectangleselect your first layercopy the selectionmake a new picture. Increase the size of the canvas by twice your border width, in each directionpaste your picture and center it (for wide borders, the align object plugin is quite helpful, but it looks like you want a 1px border.)outline your object with the color of your choice, using the outline object plugin. second way: select your image using the rectangle select toolcopy your image to a new layer, or new canvas. I reccomend a new layer.gaussian blur+ set to alpha blurring your imagelarger blurs will get you rounder cornersgo to curves+ and select alpha. set one point at the bottom and at slightly less than 128, and the other at the top and slightly more than 128.outline object to your preferenceyou're done! hope this helps! Quote Click on my signature image for my gallery | hmmmm... Link to comment Share on other sites More sharing options...
Down Posted December 20, 2008 Share Posted December 20, 2008 Just use that picture, select everything inside the border and delete it. Then save the border so you can apply it to as many pictures you like. If you want different sizes, just use the square rectangle and touch-up the corners with the pencil. Quote •♪♫♥♫♪• |- The Rules -|- çobblestones -|- CaMo -|- MeTaL -| ╠═╧╨»Φ«╨╤═╣ Link to comment Share on other sites More sharing options...
