John Stewien Posted December 19, 2008 Share Posted December 19, 2008 When I draw Pixels with Alpha they don't retain their proper value. To Reproduce in Paint.NET 3.36: New Document Select All and Clear Select the Rectangle Tool Select Draw Filled Shape With the Colors Window select ARGB 65,255,255,255 Draw a Rectangle With the Color Picker Tool sample the rectangle just drawn You will get an ARGB of 65,254,254,254 so all the RGB values are 254 instead of 255 Quote Link to comment Share on other sites More sharing options...
silverhammer Posted January 16, 2009 Share Posted January 16, 2009 Weird, I just confirmed this. It seems to happen with many RGB values not just 255, though certain values do not change when you use the eyedropper. I can only assume that PdN stores colors in a different format than ARGB so some rounding occurs when you actually draw on the image. So I don't think that the eyedropper is picking up the "wrong" color, rather the color you're actually drawing is slightly different from the one you selected. So this bug shouldn't actually affect your drawings in any way as the visual difference between 254 and 255, for example, is essentially nothing. Quote My deviantART My Pictorium Gallery My ImageShack Link to comment Share on other sites More sharing options...
John Stewien Posted January 16, 2009 Author Share Posted January 16, 2009 So this bug shouldn't actually affect your drawings in any way as the visual difference between 254 and 255, for example, is essentially nothing. Visually it might not be much different but it depends what you are using your images for. Paint.NET is a nice proggy for editing data that has been converted to image form. Unfortunately this issue is causing me grief. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 16, 2009 Share Posted January 16, 2009 It's a GDI+ issue. This bug has been reported before, and is a Won't-Fix until/if we change rasterizers (which we'd like to do eventually). Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
