unrelatedacc Posted April 4 Share Posted April 4 i wanna make a blur effect kind of like this, but no blur tool has been helpful since the bokeh in the default blur tools makes a background blur. Quote Link to comment Share on other sites More sharing options...
Tactilis Posted April 4 Share Posted April 4 @unrelatedacc Please post an example source image that you want to apply the blur effect to. Quote Link to comment Share on other sites More sharing options...
Solution toe_head2001 Posted April 4 Solution Share Posted April 4 Did you try TR's Bokeh Plugin? Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
unrelatedacc Posted April 4 Author Share Posted April 4 @Tactilisit's just a background for the text Quote Link to comment Share on other sites More sharing options...
unrelatedacc Posted April 4 Author Share Posted April 4 1 minute ago, toe_head2001 said: Did you try TR's Bokeh Plugin? thanks, that worked well Quote Link to comment Share on other sites More sharing options...
