Tactilis Posted October 21 Share Posted October 21 Version tested: Paint.NET 5.0.11 on Windows 11 Bug Description: The Help icon's tooltip is erroneously displayed if Help is activated using the shortcut Alt+H The tooltip is displayed next to wherever the mouse pointer happens to be at that time. Reproduction 1. Hover the mouse pointer over the icon and note that the Help icon's tooltip is displayed as expected. 2. Move the mouse pointer elsewhere. 3. Press Alt+H to activate Help. The Help menu appears as expected. Note that the Help icon's tooltip is also displayed. Expected behaviour: The Help icon's tooltip should not be displayed when Alt+H is pressed. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 23 Share Posted October 23 This looks like one of those weird WinForms-ism bugs. The choices is to either have this goofy behavior, or remove the tooltip altogether. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Tactilis Posted October 23 Author Share Posted October 23 6 hours ago, Rick Brewster said: The choices is to either have this goofy behavior, or remove the tooltip altogether. You don't get a stray tooltip when you press Alt+X for Settings. Is that because Alt+X displays a dialog versus Alt+H displaying a menu? Or is there some other difference between the Settings and Help buttons? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted October 23 Share Posted October 23 Settings isn't a menu, it's just a button Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Lemonade Posted October 23 Share Posted October 23 As Tactilis pointed out, Help button is the only one (in the top right buttons group) with a menu. Maybe that is the reason for unusual tooltip behavior. Quote Link to comment Share on other sites More sharing options...
Tactilis Posted October 23 Author Share Posted October 23 (edited) 17 hours ago, Rick Brewster said: The choice is to either have this goofy behavior, or remove the tooltip altogether. If nothing can be done to suppress it, then IMO it's better to have a goofy detached tooltip when the user presses Alt+H than to remove it altogether. The tooltip when hovering the mouse over the icon reveals information that's useful. Edited October 23 by Tactilis 1 1 Quote Link to comment Share on other sites More sharing options...
Solution Rick Brewster Posted October 23 Solution Share Posted October 23 Yeah and it’s not something you’ll likely use that often. It’s not like the File menu has this behavior! 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
SvenCarter Posted November 6 Share Posted November 6 (edited) On 10/22/2023 at 1:33 AM, Tactilis said: Version tested: Paint.NET 5.0.11 on Windows 11 Bug Description: The Help icon's tooltip is erroneously displayed if Help is activated using the shortcut Alt+H The tooltip is displayed next to wherever the mouse pointer happens to be at that time. Reproduction 1. Hover the mouse pointer over the icon and note that the Help icon's tooltip is displayed as expected. 2. Move the mouse pointer elsewhere. 3. Press Alt+H to activate Help. The Help menu appears as expected. Note that the Help icon's tooltip is also displayed. Expected behaviour: The Help icon's tooltip should not be displayed when Alt+H is pressed. Any update? As a student, I appreciate their transparent reviews and comprehensive analysis of essay writing services. The detailed insights provided on https://www.topwritersreview.com/reviews/topessaywriting/ empower me to make informed decisions when choosing a writing service. you can trust that your assignments are in capable hands, ensuring not just academic success but also peace of mind.The analysis aids students in making informed decisions, guiding them towards a trustworthy academic support system. Any update? Edited November 20 by SvenCarter Quote Link to comment Share on other sites More sharing options...
Tactilis Posted November 6 Author Share Posted November 6 1 hour ago, SvenCarter said: Any update? Odd first post. What update were you expecting? As @Rick Brewster clearly said: On 10/23/2023 at 1:18 AM, Rick Brewster said: This looks like one of those weird WinForms-ism bugs. The choice is to either have this goofy behavior, or remove the tooltip altogether. And then it was agreed that it was preferable to retain the current behaviour in which the tooltip appears next to the mouse pointer when Alt+H is pressed. As Rick observed: On 10/23/2023 at 7:11 PM, Rick Brewster said: Yeah and it’s not something you’ll likely use that often. It’s not like the File menu has this behavior! Yes, it's a bug, but it has zero impact on your use of Paint.NET Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted November 6 Share Posted November 6 9 hours ago, SvenCarter said: Any update? Why would there be an update? Are you a bot? Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
