MalvinoXDD Posted June 27, 2022 Share Posted June 27, 2022 hello, i tried to edit one .dds file from a game and it haves transparency. how i put it normal? Quote Link to comment Share on other sites More sharing options...
BoltBait Posted June 27, 2022 Share Posted June 27, 2022 Some games use the alpha channel not as transparency but as an indicator of how shiny something is. So, you can try using my plugin Adjustments > Transparency to raise the transparency for working on the image... then, lower it again before saving for the game. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
MalvinoXDD Posted June 28, 2022 Author Share Posted June 28, 2022 16 hours ago, BoltBait said: Some games use the alpha channel not as transparency but as an indicator of how shiny something is. So, you can try using my plugin Adjustments > Transparency to raise the transparency for working on the image... then, lower it again before saving for the game. it worked, thanks! Quote Link to comment Share on other sites More sharing options...
