not able to draw desired 3D shapes
although, I have shape3D plug in but the problem probably I am unable to use it as it supposed to be.
when I draw 3D box on a new layer it ends with failure. however, when I draw on background only then get success little bit but not as desired. it gives only a 2D shape.
I might be using it in wrong way. actually i want to draw a 3D box just like if match box has been kept on a surface.
any suggestion?
