I need help with changing colours in this picture.
Hello everyone, hope you are all having a fantastic day, I have a picture in which i want to change all the dots and squiggles to purple and make the background black. How can I achieve this i tried watching tutorials and messing about but i cant seem to figure out how to do it and off cousre i do not want to manually paint all the dots in purple. Hope anyone can help me out, thanks. The image is too big of a file and im brand new to this so ill try to figure out how i can compress it until then im happy to hear out suggestions.
OK, that's an easy one:
1. Set your primary color to Black and your secondary color to Purple.
2. Use the magic wand :MagicWandTool:with tolerance set to 0, shift click on the white area.
3. Press the Backspace key.  (That should fill your white area with black.)
4. Press Ctrl+I to invert your selection.
5. Press the Shift+Backspace key.  (That should fill your dots with purple.)
...and, you're done!
  • Like 2
Click to play:
