RichardJohnsen Posted June 8, 2006 Share Posted June 8, 2006 After buying a new Acer aspire 3000 with AMDm Sempron - 512ddr Yesterday ((due to "microsoft update" MS06-015 (908531)locking up my old hp PavN5414 lap(info on request-(Ron at Dell tried to help, but MS rewrite/fix didn't work)) My prosessing/rendering is cralwing - on a fresh 2.6 and ms net frame Have I got a crummy processor?? I own Adobe 3.0-paint, but really enjoyed the 2.5 p-.net old version, as was easy and my old celeron lap, was, fast running it. I have only put on Avast, Adware and thats all. :?: Whats my problem? :? UPDATE i found that a program called {ZOOM IN} couldn't be shut down by restarting & had to click END NOW IT or something from download was running processor @ 100% -task mgr. IT would come back at reboot. I ran system restore and am back to new fast processing HAVE HAD A-Virus on before it started happening, happened while editing/hard/rotating .pdn layers, is their a new zoom virus? Got any ideas :?: :!: Hope to use p.net again here's a OLD crash log from the MS Update, explorer lockup, on HP if you care to look Crash log for Paint.NET v2.5 (Final Release build 2.5.2153.32600) Time of crash: 4/28/2006 2:25:01 AM OS version: 5.1.2600.0 .NET Framework version: 1.1.4322.573 Exception details: System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args) at System.Windows.Forms.Control.Invoke(Delegate method) at PaintDotNet.SaveConfigDialog.FileSizeTimerCallback(Object state) Quote Link to comment Share on other sites More sharing options...
Illnab1024 Posted June 8, 2006 Share Posted June 8, 2006 Can you give all the system specs? Quote ~~ Link to comment Share on other sites More sharing options...
RichardJohnsen Posted June 8, 2006 Author Share Posted June 8, 2006 its a mobile AMD Semperon Processor 3100+ 1.8 GHz, 448 MB RAM Phys.Add.Ext. Runnin great after above edit / sys. restore on 1st post Quote Link to comment Share on other sites More sharing options...
Illnab1024 Posted June 8, 2006 Share Posted June 8, 2006 whatever it is, it's a parasite. I would suggest using Norman Antivrus (easily download at http://pack.google.com/) to search for it. Also run spybot on it, else it will come back. Quote ~~ Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 8, 2006 Share Posted June 8, 2006 Yeah this doesn't sound like a Paint.NET problem if you've got/had a virus infection. Honestly if you've had a virus the best medicine is to reformat the hard drive -- otherwise you can't be 100% sure that the virus was removed. This is especially true in this era of rootkits and such. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
RichardJohnsen Posted June 8, 2006 Author Share Posted June 8, 2006 Rick :? this brand new computor has been on the net only to google, major geeks, to down load hijacker, avast, ad-aware, paint.net, the ms net 2 then then reset, to after avast :!: find it very hard to believe that the zoom rotate function dosen't have a bug as that when it started :!: do you have a zipzoom cookie, or zoom in.exe in pnt or ms :?: if not who knows of a new trogen called zoom in if a trogen im sure it in the latest sys restore file Want to run it :?: i haven't created my sys utility restore disk yet as on partioned drive from factory am not going to reinstall your great p.net until i found what was trying to burn up my new processor , seems someone would want to know what happened so quick to new comp. with new avast avirus-updated and scaning, don't think a norton would find as it's gone to sys restore and was thinking to turn sys restore off, to be rid if it, then back on :?: could restore bad sysrestore, run hyjack, run a utility while processor is at 99% then reformat it if you want me to :?: Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 8, 2006 Share Posted June 8, 2006 I'm really having trouble figuring out what you're saying here. "Zoom in"? "Zipzoom" ? What are you talking about? I'm not trying to give you advice on fixing your computer, that's not really my domain. If Paint.NET's running really slow then maybe your power management is keeping the CPU at a lower power state, which means it's not running at full performance in order to save battery life. This is just a hypothesis mind you. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
RichardJohnsen Posted June 9, 2006 Author Share Posted June 9, 2006 thanks for your reply after first boot of this laptop i installed adaware and avast then i returned to majorgeeks to download pnt.net and ms frame 1 i started editing a pdn file & when i tried rotate/zoom a pdn layer 2 i experienced slow processing 3 i restarted the lap 4 windows reported that it couldn't shut down ZOOM IN (a running process) 5 i hit end now 6 happened again so ran task mgr. showed 100% usage of processor 7 preformed a C drive search for zoom 8 found to suspicious cookies named, myadministratorname@zipzoomfly.122.2o7 9 ran avast avirus on boot -found nothing 10 ran adaware and it didn't find those two zipzoomfly cookies 11 i ran hyjack and didn't see or understand many new reg entries so i deleated the two cookies to recycle 12 i ran sys restore, back to before, downloading your pdn and ms, and computor runs as new 14 i know i recieved either a brand new worm/virus/trogen attatched to your download file at major geeks or a bug from your programs Again this brand new lap top has been nowhere else on net If you know of anyone interested in finding the trogen or bug i'll help with my files, until i turn off sys restore and/or reformat this brand new drive, as you know it take awhile just to do that If not interested pls. just email me if you see this problem again how do I show a pdn/.png here like you do? I'll get Ron AT Dell/hijack to read this post, but i didn't save the hjt copy file. Thanks again RLJ Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 9, 2006 Share Posted June 9, 2006 Please don't accuse Paint.NET of having a worm, virus, or trojan. That's a serious accusation, and I can unsure you it's not true. ZipZoomFly.com is a website for buying computer parts. Cookies are hardly dangerous, and not something I'd worry about at this point. Most anti-malware software likes to report all sorts of cookies as "dangerous" just to make themselves look like they're helping you all the time. If "ZOOM IN" is running before you started Paint.NET, then Paint.NET is not what's the problem here. Paint.NET does not create any windows or programs called "ZOOM IN", it doesn't modify the list of startup programs, etc. This obviously has absolutely nothing to do with Paint.NET. Therefore, you will need to seek help elsewhere because this is strictly a Paint.NET forum. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
RichardJohnsen Posted June 9, 2006 Author Share Posted June 9, 2006 the fix i posted on "i had a zoom problem" thread i found ZOOM IN acer laptop bug problem in acer launch manager task manager was showing 99% on acer prog. tracked and turned off, worked guess they borrowed someones zoom in name thanks - rickb and illnab1024 rj Quote Link to comment Share on other sites More sharing options...
