BDP Posted March 31, 2022 Share Posted March 31, 2022 There is a free program available somewhere called 'Font Validator'. It is a bit tricky to run, but could help you determining if a font or fonts are corrupt in the Fonts folder Or alternatively, open the Fonts folder, select Details, and check to see if any font files have zero bytes Brian Quote Link to comment Share on other sites More sharing options...
BenTheMiner Posted April 1, 2022 Author Share Posted April 1, 2022 On 3/31/2022 at 10:47 AM, BDP said: There is a free program available somewhere called 'Font Validator'. It is a bit tricky to run, but could help you determining if a font or fonts are corrupt in the Fonts folder Or alternatively, open the Fonts folder, select Details, and check to see if any font files have zero bytes Brian No font files have zero bytes. Is there a way to check the fonts using Windows? Quote Link to comment Share on other sites More sharing options...
