osyu Posted September 29, 2021 Share Posted September 29, 2021 (edited) Hi, I've noticed that when scaling images down using nearest-neighbor, the pixels it samples from are offset when using the Resize dialog versus using Move Selected Pixels, particularly causing pixel art to be far blurrier when using Resize (especially when the initial size is not a multiple of desired size): Is this behavior a bug? I've tried rescaling this same image in some other programs/libraries like ImageMagick and PIL and they worked fine, producing the exact same result as Move Selected Pixels, so I assume Resize is producing incorrect results here. Edited September 29, 2021 by osyu Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 29, 2021 Share Posted September 29, 2021 Can you share the original image, along with exact step-by-step instructions to reproduce the issue? Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
osyu Posted September 29, 2021 Author Share Posted September 29, 2021 Original image: For Resize: - Open Resize dialog, enter 256x192 as the desired pixel size and hit OK For Move Selected Pixels: - Select the tool and set Quality to Nearest Neighbor - Manually scale the image by dragging it down to 256x192 in size Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 29, 2021 Share Posted September 29, 2021 Okay I'll file a bug and look into it Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Solution Rick Brewster Posted March 1, 2022 Solution Share Posted March 1, 2022 I figured this out -- the pixel offsets were off by 0.5 pixels I can have a fix in the 4.3.9 update 2 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
