recolor: unable to swap color to transparent (recolor works with any other color)
The Recolor tool will not work for this.
If there are areas of similar color to be removed set the Magic Wand Flood Mode to Global.
(Or hold down the Shift key).
All similar colors will be selected, then Delete.
If many of the colors are different, hold the Ctrl key down and click on
each area that you want to remove, then Delete.
Edited by ardneh
