pizzasqueeze Posted October 22, 2018 Share Posted October 22, 2018 Hello, I found this tutorial about making a VHS effect on images but I don't fully understand it can someone explain it or simply it for me, please. Here is the link: Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 22, 2018 Share Posted October 22, 2018 (so you're asking for a tutorial of a tutorial? ) Yup, there's a reason it's in the Tutorial Graveyard section. However, the steps seem to still be intact. Which part are you having issues with? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
pizzasqueeze Posted October 22, 2018 Author Share Posted October 22, 2018 I don't know what Extract Channel and BlendModes Plus is also Duplicate Layer1 Steps I don't understand that like if you duplicate the layer and then go back to the first layer. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 22, 2018 Share Posted October 22, 2018 (edited) 1 hour ago, pizzasqueeze said: I don't know what Extract Channel and BlendModes Plus There are links to those plugins directly in the tutorial. EDIT: I've moved the plugin links to the top of the tutorial, so they're easier to find. 1 hour ago, pizzasqueeze said: I don't understand that like if you duplicate the layer and then go back to the first layer. https://www.getpaint.net/doc/latest/LayersWindow.html#11 Edited October 22, 2018 by toe_head2001 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
pizzasqueeze Posted October 22, 2018 Author Share Posted October 22, 2018 Thanks for the help i will try it out to see if it works Quote Link to comment Share on other sites More sharing options...
pizzasqueeze Posted October 22, 2018 Author Share Posted October 22, 2018 It works that you so much Quote Link to comment Share on other sites More sharing options...
