Varona Posted September 5, 2018 Share Posted September 5, 2018 Hi, I was wondering about methods to superimpose images such as in the image below: What I've tried so far to replicate this effect was to apply equal transparencies to all layers, each with a different frame, but resulted in frames being less visible than the next. Is there a way to keep all frames/images equally visible? Thanks. Quote Link to comment Share on other sites More sharing options...
Djisves Posted September 5, 2018 Share Posted September 5, 2018 In this particular example, the easiest way to accomplish what you need is to add each image to a new layer and change layer all Layer Properties to "Additive" or "Lighten" (no need to do that for the bottom layer). Quote Link to comment Share on other sites More sharing options...
Varona Posted September 6, 2018 Author Share Posted September 6, 2018 (edited) Additive made everything brighter; Lighten did the same but not as much. I'll experiment with the brightness & contrasts and see what'll work best. Still, it works, but tedious to do layer by layer. EDIT: Decided Lighten works better in my case. Applying Additive to multiple layers made it look far too bright. Edited September 6, 2018 by Varona Quote Link to comment Share on other sites More sharing options...
