nrscroller Posted February 2, 2018 Share Posted February 2, 2018 HI I just got this program and I do a lot of scroll sawing. I may have a pattern I want to make either bigger or smaller. I know how to scan it and get it into the program but are there steps to take to resize it to a certain size. Say I had a small valentine heart that was about 3 x 3 and I want to enlarge it to 5 x5, what do I do to change the size simply. And why went I go to print out the pattern in windows 7 do I get this stupid print screen that wants to know what size picture I want, can't I just print out the resized pattern. thanks for the help Bill Quote Link to comment Share on other sites More sharing options...
HyReZ Posted February 2, 2018 Share Posted February 2, 2018 Hello! After your image is brought into the software; you go up to the Image tab and select Resize. When the Resize window opens you will see the current size of the image displayed in in pixels in one area and in inches in an area below. Type in the new dimensions and click ok. Quote Link to comment Share on other sites More sharing options...
Forest City Posted July 8, 2018 Share Posted July 8, 2018 (edited) I was in the same boat... I do Scroll work and what you need is Print it (tool Effects) I use it and it WORKS. I do Scroll work and have found this to be extremely valuable. Pay attention to the install instructions.... https://forums.getpaint.net/topic/28520-print-it-tools-effect/?tab=comments#comment-410117 Edited July 8, 2018 by Pixey Fixed the link Quote Link to comment Share on other sites More sharing options...
