Gator_Scientist Posted July 16, 2008 Share Posted July 16, 2008 When trying to Load Paint NET on my machine I receive the following notification: Paint.NET Setup Front-End has encountered a problem and needs to close. We are sorry for the inconvenience. If you were in the middle of something, the information you were working on might be lost. ---------Debug --------------------------------------------------------Close Quote Link to comment Share on other sites More sharing options...
HITMAN-X- Posted July 16, 2008 Share Posted July 16, 2008 Is there a crash log on your desktop ?. If so could you post the contents. You can also run the pdn repair tool found in the Paint.NET folder. Default install folder for Paint.NET is C:\Program Files\Paint.NET Quote DEXTUT.COM Link to comment Share on other sites More sharing options...
Gator_Scientist Posted July 16, 2008 Author Share Posted July 16, 2008 Sorry, no debug log was dumped to the desktop and the Front-End Loader didn't even make it to the point of establishing a folder under Program Files. I use GIMP 2.4 and have been having a problem with an error (0xc000007b) every since I upgraded to Windows XP SP3 and Symantec Endpoint Protection 11.0 [of course they are blaming each other]. This may be interfering with the load as it has also shut down FireFox and slaughtered a legacy Netscape 4.03 I was maintaining (luckily also maintained on an older Linux 8.0 system). I am aware I am trying to make a multitude of generations of software work together here, yet if that is part of the problem let me know and I will seek another avenue. Thank you. Respectfully, Steve C. Wilson Quote Link to comment Share on other sites More sharing options...
HITMAN-X- Posted July 16, 2008 Share Posted July 16, 2008 Ah I see your trying to install Paint.NET. You don't have it installed yet. I would not say SP3 is the problem as I have install Paint.NET already on about 50 Computers with SP3. I guessing the problem is Symantec Endpoint Protection 11.0. I know I have had problems with Symantec protection software before with install programs. It seems it blocking some actions that Paint.NET need to do for installing. Here some steps to try. 1) Log in as a Admin 2) Turn of Symantec Endpoint Protection 11.0 3) Run Paint.NET Installer 4) If Paint.NET installed, test run it 5) If test run worked then you should turn on Symantec Endpoint Protection 11.0 6) Test run again to see if it will work with Symantec Endpoint Protection 11.0 7) If all is good then you can log of as a admin and go back to your normal user account Quote DEXTUT.COM Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 17, 2008 Share Posted July 17, 2008 Also, try doing a Repair operation on "Microsoft .NET Framework" in the Add/Remove Programs (XP) or Programs and Features (Vista) control panel. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
