jlstx3500 Posted July 2, 2008 Share Posted July 2, 2008 im abit confused. ive never downloaded plugins before. once you download them.do they not appear in paint automatically? or do you have to do additional steps? because if so i have no idea what to do after it is downloaded. help please Quote Link to comment Share on other sites More sharing options...
Myrddin Posted July 2, 2008 Share Posted July 2, 2008 Hello jlstx3500. You appear to be confused about the Rules as well . You really need to be more careful where you post; as you may have noticed, the section where you first posted this does happen to be titled with Publishing Only. Posting in the General Discussion and Questions section would have been far better, to where this topic has been moved to. Having said that, if you would care to look around or search, you would have also noticed a topic which reads How to install plugins/General plugin troubleshooting. You can find it at the top of the Plugin section of the Forum, here: viewtopic.php?f=16&t=2023. In that topic, it will take you through the steps to installing plugins. Also check this tutorial, too: http://boltbait.googlepages.com/install Don't hesitate to post again as we'd be more than happy to lend a hand in help, bearing in mind the Rules . Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
