Paint_boy
Posts
689 -
Joined
Last visited
Posts posted by Paint_boy
Nice tut. Heres my try:
It's a little bit of touch up.
Well... out of all my programs Audacity is the only suggestion and Audacity is an audio editing program. :?:
Man most of pyrochild's plugins should be included in paint.NET especially his + ones.
EDIT:
What do you open a DLL with? Word? DLLFileOpener? If even is such a thing.
a car I made
Isn't that Forza for xbox?
The car is in the game, but it is a real car.
Eek!
Awesome extension! I have some suggestions.
1. Use capitals
2. With the mode black white/color maybe do a check box labeled "Color?" and checking it would cause color.
Eek! It crashes when I use it
Please e-mail this file to paint.net@hotmail.com so we can diagnose and fix the problem.
Application version: Paint.NET v3.10 (Beta 2 Release build 3.10.2779.25584)
Time of crash: 8/19/2007 4:08:37 PM
Application uptime: 00:00:49.4510000
OS Version: 6.0.6000.0 Workstation x86
.NET Framework version: 2.0.50727.312 x86
Processor: 2x "AMD Athlon 64 X2 Dual Core Processor 3800+" @ ~2003MHz (DEP, SSE, SSE2, SSE3)
Physical memory: 2045 MB
Tablet PC: no
Exception details:
PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.DivideByZeroException: Attempted to divide by zero.
at PaintDotNet.Effects.UserScript.Render(Surface dst, Surface src, Rectangle rect)
at PaintDotNet.Effects.UserScript.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length)
at PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.RenderImpl()
at PaintDotNet.Effects.BackgroundEffectRenderer.Join()
at PaintDotNet.Effects.BackgroundEffectRenderer.Start()
at PaintDotNet.Menus.EffectMenuBase.EffectConfigTokenChangedHandler(Object sender, EventArgs e)
at PaintDotNet.Effects.EffectConfigDialog.OnEffectTokenChanged()
at PaintDotNet.Effects.TwoAmountsConfigDialogBase.amount2Slider_ValueChanged(Object sender, EventArgs e)
at System.Windows.Forms.TrackBar.OnValueChanged(EventArgs e)
at System.Windows.Forms.TrackBar.set_Value(Int32 value)
at PaintDotNet.Effects.TwoAmountsConfigDialogBase.amount2Reset_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
Wow That's amazing. Stuff for my iSafari theme thing just keep on getting better and better. New forums, extension, chat room, now search engine unfortunately I haven't been working on it for weeks.
I have a question. I'm not sure what to do at Advertising status. I don't know what to select.
How did you get it onto your own URL with a custom icon and not have all that user stuff at the bottom?
How did you set up this search engine?
Nothing, anymore. He had a bad quote tag that broke the layout.
Oh. how do you get a bad quote tag?
@Bjerre: Please fix your post.
What's wrong with his post?
Wow. This tut is amazing! I'll try not to mess up and post my result.
I can't download it. Can someone just send me the direct DLL?
I agree but this is very very helpful!This is more than defentions than a real tut.Is GIF lossless format? When I save it it doesn't appear fuzzy but it looks weird.
This is a question about the Jpeg. Why is it such a bad and lossy format, yet so many people use it? I think PNG is best and should be used for most things.
Well seeing Microsoft did the ribbon UI thing will IE8 have a ribbon UI or the next windows?
Do you want to make the black parts white and the white parts black, or do you want to invert the luminosity of each pixel while preserving the hue?
If the latter, the Edfects Plugin Pack has a filter called Invert Intensity which will do just that.
The first one
I was wondering how do you just invert the black and white parts of an image?
PDN just crashed. I just opened PDN from a PNG image and went into color > White Balance and it crashed.
EDIT:
It crashes when I click on anything ed harvey so I guess its a plugin problem >_>
This text file was created because Paint.NET crashed. Please e-mail this file to paint.net@hotmail.com so we can diagnose and fix the problem. Application version: Paint.NET v3.10 (Beta 2 Release build 3.10.2779.25584) Time of crash: 8/17/2007 10:19:04 AM Application uptime: 00:00:39.6370000 OS Version: 6.0.6000.0 Workstation x86 .NET Framework version: 2.0.50727.312 x86 Processor: 2x "AMD Athlon(tm) 64 X2 Dual Core Processor 3800+" @ ~2003MHz (DEP, SSE, SSE2, SSE3) Physical memory: 2045 MB Tablet PC: no Locale: pdnr.c: en-US, hklm: en-US, hkcu: n/a, cc: en-US, cuic: en-US Exception details: System.IO.FileNotFoundException: Could not load file or assembly 'EdHarvey.Edfects.Common, Version=0.6.2690.12792, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. File name: 'EdHarvey.Edfects.Common, Version=0.6.2690.12792, Culture=neutral, PublicKeyToken=null' at EdHarvey.Edfects.HueSatConfigDialogBase.InitializeComponent() at EdHarvey.Edfects.Effects.WhiteBalanceEffectConfigDialog..ctor() at EdHarvey.Edfects.Effects.WhiteBalanceEffect.CreateConfigDialog() at PaintDotNet.Menus.EffectMenuBase.RunEffect(Type effectType) at PaintDotNet.Menus.EffectMenuBase.EffectMenuItem_Click(Object sender, EventArgs e) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at PaintDotNet.PdnMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. ------------------------------------------------------------------------------
Programs I had opened: Firefox and iTunes
isit possible to add music/sound to gif files?
Idont think so....
No. you can do that to videos though.
Here is mine. Anyone care to try it out? It is hilarious!!!
Awesome tut for your awesome Plug-in.
EDIT: I couldn't read the message in Davids sig, i tried but some words were just apsolutey positively impossible to read.
I pre-ordered halo 3
Also this is an awesome plugin that you guys should try. for all you know you might find some hidden images in signatures avatars etc...
After studying a little bit more now I know what the ribbon is. I think that's a great idea and I'd love to have that in Paint.NET
After seeing this screenshot: http://www.nishanthchandran.com/wp-cont ... e-2007.jpg
I wouldn't mind having a UI like that in paint.NET. I think I would actually like it.
Someone please make this a plugin...
That would be very nice.
Thank you, that's a OK solution.
But it would be nice to have a crop-function, like in photoshop, where you can type the size in px/cm/inch and the resolution in dpi.
I believe it's on the roadmap.
I hope so. Although I love Paint.NET there are some things that I don't like and that happens to be one of them.
What does that interface look like? I don't have office 2007 I have word 2002 or something like that. If someone shows me a screenshot or something could you tell me what part they want the UI to look like?
S3D#2:Realistic eyes(EASY)+Slit pupil+
in Creations
Posted
I don't know if this is much better
