pn_user Posted January 19, 2006 Posted January 19, 2006 Using: 2.6 Beta 2 PC: Dell Laptop with Windows 2000 with SP5 The default settings for Windows PCs is to have the display set to Small Fonts (96 dpi). With higher resolution screen becoming more common, I find myself using the Large Fonts (120 dpi) setting to help with readability. However, many applications do not anticipate this, and as a result sometimes these programs become unusable as you can't see all the text or the windows do not scale properly. With Small Fonts, Paint.NET works fine ... no problems. With Large Fonts, Paint.NET does not become unusable, but there are several areas that are affected, a partial list of those are: Install Wizard: Parts of the text is hidden under the top banner. Tools Window: Title bar changes from 'Tools' to just 'T...' The word 'Tolerance' is cropped as it tries to fit into the tolerance bar Popup windows for Layers -> Adjustments and Effects. The most notable are under Effects. One of the best examples is the red eye reduction pop up window, a portion of the text for the 'Hint' is lost and the word 'Reset' does not fit on the buttons. I'm sure they may be others, these are just those that I noticed quickly. Quote
Alph Tech / STUART Posted January 20, 2006 Posted January 20, 2006 However, many applications do not anticipate this, and as a result sometimes these programs become unusable as you can't see all the text or the windows do not scale properly. Yep. That's a sad fact of Windows development that has been mentioned on the Microsoft Fontblog. Quote
