Piranesi Posted July 15, 2007 Share Posted July 15, 2007 I've a simple black and white logo that I merely wish to replace a large amount of the white area with nothing aka transparent pixels. As you might have guessed; I'm not experienced using a tool like this. What I tried doing so far is to use the magic selection tool and then cut out all the desired white areas. I put a solid colored layer underneath so I could tell I was getting the desired effect and all looked good. Then I saved the file. This is a .jpg file. After the save the file no longer retains the transparent effect. What am I doing or not doing that I need to do? TIA - Dale Quote Link to comment Share on other sites More sharing options...
Myrddin Posted July 15, 2007 Share Posted July 15, 2007 .jpg for transparency is a big no no. Try saving as a .png as this will keep the true alpha values, but bear in mind you'll want to delete the solid colour layer underneath otherwise you'll be forced to flatten it and that would be defeating the purpose of saving for transparency. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
Piranesi Posted July 15, 2007 Author Share Posted July 15, 2007 thank you - that did the trick Quote Link to comment Share on other sites More sharing options...
