Posted
Hi there!
Some few month ago I found this very good software and worked with it and with my 1920*1200 24" monitor with no problem.
Recently I changed my monitor to 2560*1440 27" and there starts the problem.
The flickering occurs, if I start and end (or change to desktop with ALT+TAB) my flightsim.
(I create some terrain for the sim, so I change with ALT+TAB between Paint.Net and the sim.)
Before starting the sim no flickering occurs. Since the sim started flickering occurs, if I paint e.g. a rectangle, even if I load some images via drag&drop (everytime a picture loads it is flickering).
This flicker is not all over the monitor, only at the lower screen edge and in size of the taskbar.
My OS: Win7 64bit
Paint.Net: 3.5.11
Recently I've downloaded version 4 and I will give it a try.
Maybe you can give an advice how to avoid this flickering.
TIA
Earlybite
Posted
Hi,
I reinstalled all<!>. Win7, all m software...and used the newest AMD driver for my GigaByte HD 7770. And it works now...
But it's a little weird that flickering occurs if you change your monitor from 1920*1200 24" to 2560*1440 27" if you use ALT + TAB , isn't it?
But ok, it works now.
Regards
Earlybite
Posted
Earlybite,
Sorry I missed this before, but this does not sound like a Paint.NET issue;rather, a video card driver issue.  Increasing the size of your monitor may have overtaxed it.
Posted
Hi david,
yes you are right! :)
My specs:
i5-IVY-Bridge-3450 3,1 GHz, GigaByte HD 7770
I would had known if there would have been something overtaxed ;)
Serious, I couldn't imagine that a new monitor can cause flickering *if* switching with ALT + Tab:
Remember that I hadn't had any flicker with this new new monitor *before using ALT + TAB!
In my opinion it is weird...
But, how ever, no<!> it was no paint.net issue!
And to find help I decided to sign in...
I feel very well with this software. Exellent job!
The only thing now is, if I used ALT + TAB, that the arrangement of the windows of paint.net is lost. I always have to change to full size and back to normal window size of paint.net.
This can be a windows issue, or one of paint.net <shrug>
Thanks
Earlybite <who is creating tiles with paint.net>
