AppDev Posted November 25, 2011 Share Posted November 25, 2011 (edited) Hi all, I have written a simple plugin which draws an Arrow. Arrow is made up of two polygons. Left and Right. Each side has different color. I want to resize any side such that it maintain the symmetry and shape of the arrow. I have achieved this only if the Arrow head is an equilateral triangle. But if its not equilateral then Arrow gets de-shape. I have attached screenshot for the reference. Also if i resize 1 side and then resize other side arrow again gets de-shape. What will be a generic algorithm to achieve this. I want that Arrow maintain it symmetry in any way i resize it. Regards Edited November 25, 2011 by AppDev Quote Link to comment Share on other sites More sharing options...
warfighter67 Posted November 26, 2011 Share Posted November 26, 2011 (edited) This actually gives a unique effect, makes for good house outlines. Anyways, instead of rendering two sides individually, I would just render the arrow as one color, then use an algorithm to color one-half of the arrow. Would be kind of a redundant plugin though, as you can just make an arrow using PDN's line tool then re-color one half to your liking with relative ease. In my opinion, you should keep the plugin as-is, adding some unique features for a unique plugin! Edited November 26, 2011 by Weylin Quote My Soundclick!--Well of Souls MMO--Gallery--Facebook--Photobucket--Cool Tile Texture! Link to comment Share on other sites More sharing options...
