jtredennick Posted July 30, 2011 Share Posted July 30, 2011 I am a convert from Paintshop Pro (old version). There is one feature I miss and can't figure out in Paint.net. Specifically when I lasso a section of a screenshot and move it, I would like to leave behind a chosen background color in its place. This was easy in Paintshop but I can't figure out how to do it here. Instead, I seem to have to grab another selection, copy it and put it over the transparent part. Simple enough to do but cludgy. Looked at the manuals and couldn't find a mention. Thanks for all advice. John Quote Link to comment Share on other sites More sharing options...
pyrochild Posted July 30, 2011 Share Posted July 30, 2011 Create a new layer and fill it with your background color. Put this layer under the layer you're working with. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
jtredennick Posted July 31, 2011 Author Share Posted July 31, 2011 Create a new layer and fill it with your background color. Put this layer under the layer you're working with. Thank you. I tried your method but haven't figured out how to size a layer or create one to size. However, I did realize that I can pick a color and then use the bucket tool to fill the transparent region with that color. That is a click or two more than desired but perfectly workable. I can also copy another region and move it over to cover the transparency. That's good enough for my purposes. Quote Link to comment Share on other sites More sharing options...
