pleabo Posted January 20, 2011 Share Posted January 20, 2011 (edited) This is a slightly different Color Replacement plugin. Another replace tool which might work better on some images. Color replacement is very image dependent, and different approaches work better on different images and even when it is pretty good, you may have to touch it up to your satisfaction. This one allows source color selection with either a cursor on a thumbnail of the image, or the using the primary color. Then selection discrimination can be with either Hue or RGB and there is a tolerance slider. The selected color may be made Transparent, replaced with a Solid Color or replaced with a Hue The selection can be Reversed. i.e. change the colors not selected If replacing with hue, the Intensity and Saturation can be modified with sliders The new color is selected with a color wheel Here is the User Interface: (Click to see full size) and some results: (Click to see full size) Works best on images with distinctly different colors. Unzip and place the DLL in the Effects folder. V1.0 DPL Color Replacement.zip and find Effects->Color->Color Replacement Edited February 1, 2011 by pleabo Quote Link to comment Share on other sites More sharing options...
