Blending help
I am new to editing with Paint (did a lot of simple straight out drawing with it but not layering) and have only used the simple drawing parts of it so far but I need help in adding 2 pictures together so they look natural.
How do I blend them so they look seamless.
These are the 3 I am currently working on.
thank you
http://www.mediafire.com/?xxp7mta3tmafivt
http://www.mediafire.com/?d5vd788wdfdhy5f
http://www.mediafire.com/?i50d2tc027wm2kz
They are all different Discworld images I am trying to blend to look natural. Let me know what I should try.
Edited by Tawnos76
IXOYE
Gave alpha masking a try but I think I still am missing something as I did not see much of a difference.
How do you cut the edges off around the picture like you did in the example you posted up.
Here is what I got when I tried to merge and blend.
and
IXOYE
Make a mask in black on a new (transparent) layer.
Copy the mask into the Windows clipboard, then switch to the image layer
and apply the Alpha Mask effect with no checkmark in the top box.
Here's a recent thread with some links relating to Alpha mask use.
This is partly the original/partly a reproduction of the masks that I used originally.
http://img513.imageshack.us/img513/6252/disconemaskpng.png
Thanks for the help. I did some cutting as well and here is what I ended up with. Much better than my earlier trials.
IXOYE
