lorri Posted November 18, 2009 Share Posted November 18, 2009 Hi guys can one of you help me please. I have a problem with the smudge plug in I can use it. I keep download it unzip it put it in the effects folder and go to paintnet software to do some smudging it won't work so I deleted it from the effects folder I repeated this 2 or 3 times and it still not working. Why is it not using properly? any help will be appreciated thanks Quote Link to comment Share on other sites More sharing options...
becauseilearn Posted November 18, 2009 Share Posted November 18, 2009 Make sure when you unzip it that you overwrite all of the files in the archive, or else it keeps the old files. And you do need to install every file in the archive, not just smudge. Quote Link to comment Share on other sites More sharing options...
lorri Posted November 18, 2009 Author Share Posted November 18, 2009 I'll try it and see what happens thanks. If it doesn't work I'll come back to you Quote Link to comment Share on other sites More sharing options...
lorri Posted November 18, 2009 Author Share Posted November 18, 2009 That has worked, thank you very much for help Quote Link to comment Share on other sites More sharing options...
becauseilearn Posted November 18, 2009 Share Posted November 18, 2009 Glad it worked! Quote Link to comment Share on other sites More sharing options...
