mick Posted August 9, 2006 Share Posted August 9, 2006 Hi I am having some problems with this builtin tool. I created 3 rectangle solid shapes and colored then each of a single color - red green blue. Then I tried to change the green rectangle to yellow by selecting the primary color (color dialog) to yellow and the secondary color to green. But nothing happens. Should there be another btn to click - ie meaning "change the color NOW" after I've done the color selection above?. I also tried holding the CTRL and left and the right mouse BTN but same thing - nothing happens. Also reversed the primary/secondary color - nothing happens. Am using PDN v2.70. Thanks Quote Link to comment Share on other sites More sharing options...
trickman Posted August 9, 2006 Share Posted August 9, 2006 you have to click and drag the brush around the green rectangle... and maybe change the tolerance Quote Link to comment Share on other sites More sharing options...
