alator Posted June 12, 2009 Author Share Posted June 12, 2009 Hello. I'm using the .dss plugin to mod textures for a game. However, it doesn't save alpha channels correctly, so that when I install the textures, they are all "shiny". When I use GIMP, it seems to work, but only if I select a "lock alpha" button. Is there something similar I can do with paint.net? The GIMP UI is horrible, and I'd prefer to use your program. Thank you. Quote Link to comment Share on other sites More sharing options...
alator Posted June 12, 2009 Share Posted June 12, 2009 Hello. I'm using the .dss plugin to mod textures for a game. However, it doesn't save alpha channels correctly, so that when I install the textures, they are all "shiny". When I use GIMP, it seems to work, but only if I select a "lock alpha" button. Is there something similar I can do with paint.net? The GIMP UI is horrible, and I'd prefer to use your program. Thank you. Quote Link to comment Share on other sites More sharing options...
david.atwell Posted June 13, 2009 Share Posted June 13, 2009 I think it is more likely that the game doesn't load alpha textures properly, if you have to use a hack in GIMP and it doesn't work in PdN at all. Try saving as a .PNG from Paint.NET, opening it in GIMP, then saving it. Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
