GreyhoundGuy Posted July 24, 2006 Share Posted July 24, 2006 First of all, fantastic program!! It has been fitting my needs very well as I've been developing my classroom website with logos, personal graphics, etc. I was wondering if it's possible to select an area of an image using a ratio. I know PhotoShop has this type of option, as well as a constrained and/or fixed selection size, but I haven't been able to get Paint.NET to do it. For example, can you specify that you want a ratio of 6x4 (or other ratio), then crop the image and resize to the correct size? I know that you can see the proportions of your selection in the status bar of the screen, and that I can figure out a pretty close approximation. I just thought the selection by ratio would make my life easier. Any thoughts, or might this be a feature in a future version? Thanks, GreyhoundGuy Quote Link to comment Share on other sites More sharing options...
Crazy Man Dan Posted July 24, 2006 Share Posted July 24, 2006 To the extent of my knowledge, Paint.NET does not have this at this time. I have however used a method to constrain a selection to a ratio before, so you may be able to get some use out of it too! For example, for a 4:3 ratio, make a selection 4 units by 3 units (units = px, cm, in, whichever you're using), then switch to the Move Selection tool and scale the selection up, making sure to hold [shift] to constrain the ratio. Just make sure that you grab one of the corner handles, not one of the side handles. Hope that helps! Quote I am not a mechanism, I am part of the resistance; I am an organism, an animal, a creature, I am a beast. ~ Becoming the Archetype Link to comment Share on other sites More sharing options...
GreyhoundGuy Posted July 24, 2006 Author Share Posted July 24, 2006 Crazy Man Dan... you are fantastic! I just tried your idea out, and it worked perfectly. I was going for a 6:4 ratio, so I zoomed in to 800%, made a 6x4 selection, scaled it out so it was big enough to use in the 100% view, zoomed out, scaled it to perfectly fit the image, cropped it, resized it to the right size, and it is absolutely perfect! Thanks for the great idea!! -GreyhoundGuy Quote Link to comment Share on other sites More sharing options...
