Mr Noob Posted December 6, 2008 Share Posted December 6, 2008 Hi I am new to paint.net + these forums. Where is the offset tool? How do I make a texture seamless? Thanks Quote Mr Noob. Link to comment Share on other sites More sharing options...
Crazy Man Dan Posted December 7, 2008 Share Posted December 7, 2008 Greetings. There is no Offset tool/effect built-in to Paint.NET*, but if you use SearchPaint.NET and search for seamless texture, the first two results you'll get are for two different plugins that can help you. Click the link and give it a shot! You'd find the URL for that search engine - along with some other guidelines to keep in mind - in our [rule=top]Forum Rules[/rule]. Give them a read-through too if you haven't yet. Cheers. * Per se. You could try Rotate/Zoom with tiling enabled and drag the Pan line around (or set the X and Y Pan boxes both to 1 for a straight swap). You can give that a shot too if you need greater flexibility, but the plugins there are set as the more traditional 4-corner-swap style of offset. Quote I am not a mechanism, I am part of the resistance; I am an organism, an animal, a creature, I am a beast. ~ Becoming the Archetype Link to comment Share on other sites More sharing options...
