-WF- Posted January 15 Share Posted January 15 Is there any chance these hotkeys could be implemented in Paint.NET? I’m aware of Ctrl+Tab and Ctrl+Shift+Tab for tab navigation, but Ctrl+PgUp/Dn are also pretty standard, and Paint.NET is the only program I use regularly that doesn’t support those hotkeys for some reason. (I checked the docs and they’re not assigned to any other function.) Also there appears to be no way to reorder tabs from the keyboard, it’s just drag & drop only. Ctrl+Shift+PgUp/Dn is standard in most programs that support tabs, could they be added to Paint.NET as well? Thank you for considering my suggestion. Quote Link to comment Share on other sites More sharing options...
Solution Rick Brewster Posted January 15 Solution Share Posted January 15 Seems worth considering, I've filed an issue to track this on GitHub Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 20 Share Posted June 20 This has been implemented for the upcoming 5.0.7 update. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
-WF- Posted June 21 Author Share Posted June 21 Thank you! Quote Link to comment Share on other sites More sharing options...
