dratini323 Posted April 17, 2020 Share Posted April 17, 2020 I have anti aliased image where to the left and right of pixels there is a blur between orange and grey. So if I have a 3 pixels wide 4 pixels high chunk of grey with a 1 by 4 chunk of grey-orange to the left and right of it, how can I make paint.net replace all the grey-orange pixels to the left of it with grey and all the ones to the right with orange? Quote Link to comment Share on other sites More sharing options...
NinthDesertDude Posted April 18, 2020 Share Posted April 18, 2020 (edited) Converting gray-orange pixels to gray is as easy as selecting them and making them grayscale (Adjustments -> Black and White). Coverting gray-orange pixels to orange is craftier. You can select the image and invert selection so whatever you do doesn't affect the image, then set your brush color to orange and paint over the intermediate pixels. You can then soften the hard edge you just created by changing to gray, lowering opacity, and using the edge of the brush to make edge pixels gray (to keep some anti-aliasing). If you don't want anti-aliasing, even easier. Edited April 18, 2020 by Joshua Lamusga Figured out what was intended. Quote Link to comment Share on other sites More sharing options...
dratini323 Posted December 19, 2020 Author Share Posted December 19, 2020 thank you man, i never saw this until now and i forgot what i needed this for but i appreciate it anyway. Quote Link to comment Share on other sites More sharing options...
