paintdotstarter Posted August 12, 2008 Share Posted August 12, 2008 Hello !!!! I am new here.... and I have just started to use PDN3.55..... .so far so good..... it's a very good program..... Now I have question..... I have just downloaded the scanline effect from a plugin-website.... and it works fine... But I want to use the scanline effect diagonal.... to make a top banner like it is shown here... http://www.the-digital-artist.de/website/Startseite-1.html Is there somebody who can help me.... with kind regards... paintdotstarter Quote Link to comment Share on other sites More sharing options...
KJslove1994 Posted August 12, 2008 Share Posted August 12, 2008 The diagonal lines plugin might suit you a little better. You can control angle and width. http://paintdotnet.forumer.com/viewtopic.php?f=16&t=6483&st=0&sk=t&sd=a&hilit=diagonal+lines Or you can use rotate/zoom located under layers Quote Link to comment Share on other sites More sharing options...
paintdotstarter Posted August 12, 2008 Author Share Posted August 12, 2008 THX !!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
