Size problem with paste from clipboard
I am getting odd behavior with the newest version of paint.net when pasting images from the clipboard (see image below).  When I "Ctrl+c" the image from (word, power point), the image appears at very low resolution when pasted into paint.net. However if I right click and save image instead of "Ctrl+c", and then open that image from file, it keep the correct size/resolution.  The paste image is the correct size when pasting into other programs such as powerpoint or windows paint.
