deepseedy Posted January 12, 2017 Share Posted January 12, 2017 I like using the sketch tool that comes standard with Paint.net. But I've noticed that when applied to lower quality images, it doesn't really work. If the image isn't high resolution, then it mostly just fills in the pixelation and doesn't really detect the edges very well. Is there a work around to this issue, or a perhaps another tool, that could better "sketch" images of lower resolution? Quote Link to comment Share on other sites More sharing options...
Eli Posted January 12, 2017 Share Posted January 12, 2017 Try Edge detection. 1 Quote Link to comment Share on other sites More sharing options...
deepseedy Posted January 12, 2017 Author Share Posted January 12, 2017 (edited) 13 minutes ago, Eli said: Try Edge detection. Wow, that actually helps a lot. I'm supposing it's meant to be used as a layering pattern since it removes all of the color? Either way, doing so gives you nicely defined edges! Edited January 12, 2017 by deepseedy Quote Link to comment Share on other sites More sharing options...
