jeremyw9 Posted June 30, 2008 Share Posted June 30, 2008 Hey, I'm having trouble creating a sierpinski triangle with the codelab plugin. Essentially, whenever I run my piece of code, it does what I want it to, but only on one row. To make a complete triangle, I have to repeat the effect multiple times. I've used a while statement, but it doesn't work. Edit: Just thought of one possible reason. When I check if the pixels are a certain color, does it take the color which my effect makes them, or their original color? If it's there original color, could someone explain to me how to get around this? Edit2: Never mind, after looking through the Code Lab help files a bit, I now see where I went wrong. I was checking the source canvas, rather than the destination canvas. Quote Link to comment Share on other sites More sharing options...
Myrddin Posted June 30, 2008 Share Posted June 30, 2008 Do remember to post in the correct section. You have a technical question related to effects development, the Effects API / Programming section would be the most logical place to post. Moved to Effects API / Programming Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
