Tubular Tos
Posts
93 -
Joined
Last visited
Content Type
Events
Profiles
Forums
Blogs
Gallery
Downloads
Posts posted by Tubular Tos
:wink: Ok ! Illnad1024 ! So i must await that Rick include this plugin into the next version too ! :wink:
:? :shock: Did i say something wrong ? or rude ? i hope not . :?
Translate is too difficult to me ! :wink:
:wink: Thanks Illnab1024 ! I think that the texture of the planet at right seems to be real but i don't know how to do with the planet at left , it doesn't seem to be spheric .. :wink:
:? One more time i've downloaded this plugin (the last version) , dezipped it into my Pdn effects folder and one more time it doesn't work .Everytime i open Pdn and try to do something the interface "goes frozen" and i must to close Pdn (with difficult and the usual error message ) When i take off the dll from the effects folder Pdn works fine again ! :?
I know that i'm a "newbie" but i don't see where i have made the mistake ...( this time ) :?
Please can you explain me or help me ? No response on the troubleshooting forum .
:wink:
:wink: Thanks Leif !
I tried to recreate a laser that comes from behind the watcher and goes a long way ahead .
:wink: Hello there ! Just a little thing i present you ! Please ell me what you think about it !
What do i do ? Stop or continue with Paint.net ?
Thanks ! :wink:
:wink: Ok Bob ! Thanks !
Yes i have always this problem: when i try to use the plugins effects from the forum , they don't work and they "" freeze "" Pdn... Hope you'll understand me . :?
Gradients effects don't work and rectangular to polar too...
I'm lucky that Rick has included some of them into the 2.70 version . Hope this will continue....
In few days i think i'm going to dare to put some "works" of mine on the Pictorium forum .......
:wink: Thanks Rick and thanks Bob !
:x But there's again something that goes wrong ...
This plugin : http://paintdotnet.12.forumer.com/viewtopic.php?t=1849 , for example , has crashed several times Pdn .
I'm going to try with an another plugin ...
Rick ? Please ?
Can i delete the folder named Pdn setup into c:/ Documents and settings / my name / Local settings / Temp / ?
Thanks to you .
:wink: Rick ? Bob ? and all of you guys who have tried to help me .. I want to tell you that i have installed 2.70 successfully ... Now i must wait for some days to see if it runs correctly ...
( i'm going to explain you with my bad english )
:oops: The first time i have seen this post http://paintdotnet.12.forumer.com/viewtopic.php?t=243&highlight=spooky i was so in a hurry to repair Pdn that i don't have seen there was two pages , so i don't have seen the solution of Huyaowen : ( remove "all users : no name with windows install clean up )
It seems that it works now
Ok you can kick me !
What can i do now , to translate 2.70 into French ? I don't know if the older french translation pack works yet ?
Thanks again for all of you ! :wink:
Well i know that ! Rick ! and i try to do that with the more attention i can !
Yes Rick i tried all the troubleshooting steps.. Why Windows tell me that version 2.64 is still installed ? There's no Paint.NET entry into add/remove and windows install clean up doesn't see anything about Paint.Net . Can't understand ! :shock:
Thanks to you :wink:
:wink: Hi !! c:/windows/installer was into the hidden folders ... I've just found it . Into this installer folder there's an another folder with a number like this : {xxxxxxxxxxxx} and into this one , there's again an another folder with a number like this : _xxxxxxxxxxxxx.exe (weight= 101 ko ) When i click this one a window command( cmd) runs and stops at once and there's no result... The picture with this folder seems to be the Paint.Net logo( a blue sky with a paintbrush ) . Can you tell me if it's really a Paint.Net folder ? and can i do something with this folder ? .... like to delete registry entries about this folder with regedit and then install the new version 2.70 . Hope you understand me :? Thanks !
Hi there ! I'm very sorry that there's nothing to help us : "the scatterbrains" ...
Rovshand ? i'm in the same situation like you.
And i think there's no solution for us ..or just this one Format C:
I tried to install 2.70 but same thing ; setup doesn't start and Pc slow down !
When i go to the temp files to search pdn setup , the setup into it start but stop and tells me that my processor doesn't support this sort of package
More and more problems ! I can't understand because there's just with this install that i have problems and my pc , with all the sofwares in it , works fine
I hope that Vista will help us .. Saint Vista ! Pray for us !!
:? I'm sorry Rick . I've already seen this post ..No problems to install/uninstall other things ..And Windows install Clean up doesn't help me because i don't see the older version to remove it ( no Paint.net "position" ) What is this Msi Zap ? Where can i found it ? Thanks to take time to help me Rick !
Nothing nothing always the same error : can't remove the Paint net older vesion 2.64...... Thanks to you Illnad 1024
No solution found ? Please ? Can you help me ! I really need Paint.net ! Thanks to you !
It says : To install this product use the setup wizard No no it's too much for me now i'm sorry there's no solution
Perhaps with an old version ? I think that it could be a solution , no ? But there's no old version nowhere !
:shock: It's going to be funny !! I'm sorry but it doesn't work ! I have the same error ! :shock:
Le volume dans le lecteur C n'a pas de nom.
Le num‚ro de s‚rie du volume est 5009-CC14
R‚pertoire de C:\Program Files\Paint.NET
16/07/2006 23:28 .
16/07/2006 23:28 ..
16/07/2006 23:28 Staging
0 fichier(s) 0 octets
R‚pertoire de C:\Program Files\Paint.NET\Staging
16/07/2006 23:28 .
16/07/2006 23:28 ..
16/07/2006 23:28 6ÿ297ÿ088 PaintDotNet_939505196.msi
1 fichier(s) 6ÿ297ÿ088 octets
Total des fichiers list‚sÿ:
5 R‚p(s) 54ÿ699ÿ937ÿ792 octets libres
Is this what you need ?
One thing !!! I have the Framework 2 (x86) . Is this the version i need ?
Well.... I'm just going to clean one more time my pc with regedit with Jv 16 power tools and manually removing the Paint.net folder into c:/ program files
no entries into add/remove..etc.. I have used one more time the full install so Framework 2 is installed but at the end the Paint net install doesn't finish Always error 1603 ...can't remove the older version..ec.. But i have no older version installed on my pc :shock: :shock: And windows install clean up doesn't help me :shock: :shock:
Illnab 1024 , the first time Paint.net worked fine , it was installed into c:/ Program files but now there's no folder there because i deleted it manually . Is this the error i made ? When Paint net began its install , i let it to choose its proper directory...
:wink:
Système d'exploitation Microsoft Windows XP Home Edition
Service Pack du système Service Pack 2
I
Nom d'utilisateur Philippe
Carte mère:
Type de processeur AMD Athlon XP, 2000 MHz (7.5 x 267) 2400+
Nom de la carte mère Asus A7V8X (6 PCI, 1 AGP, 3 DIMM)
Chipset de la carte mère VIA VT8377 Apollo KT400
Mémoire système 1024 Mo (DDR SDRAM)
Type de BIOS Award Modular (09/02/04)
Moniteur:
Carte vidéo Gigabyte RADEON 9200SE SERIES (128 Mo)
Carte vidéo RADEON 9200 SERIES - Secondary (128 Mo)
Accélérateur 3D ATI Radeon 9200 SE
Moniteur LG F700B
I want to tell that my Xp home edition is not a pirated version so i don't understand this problem . Must i uninstall again Net .Framework to réinstall it properly ? Thanks to you
No it doesn't work now ... a message during the installation says : can't remove older version etc etc and then no install .. Too much complications for me , i must give up this fantastic software...
Thanks for all of you !
:wink: Yes Rick of course : effects dlls into effects folder and photoshop file dll into file types folder . :wink:
After more verifications Paint.net doesn't work fine : a new bug : i can't modify a picture ..
Uninstall and réinstall....
:x :x Paint.net seems to work correctly but my first problem is still there : i can't use the effect plugins from the forum and now this is all the plugins .
There's just one plugin who works ; this is the Photoshop file plugin .
Glow , gradient , distortion , photoflood and Vandermotten don't work and they freeze Paint.net and then it crashes .
Blurs doesn't appear into the effects menu
I'm very sad that i can't use Paint.net completely ! What's the problem ! :x :x
:wink: Yes ! Illnab 1024 , i think the problem comes from the "pdnsetup" into c:/.../ local settings / temp
Bob ? this is Panda titanium 2006
:x Thanks illnab 1024 .
I have cleaned all the "registry" with regedit and used the link that you have given me .
The install has started correctly for Framework but the same thing again for Paint.net : no install and Pc slow down .
This has begun to irritate me seriously when i have thought about something : ... i have removed , just for the install , my " antivirus " and so the firewall included . And " Miracle " : the Paint.net installation has begun and has finished correctly ; this is what i think but now i must await to see if Paint.net can check for next updates ; i hope that Paint.net will check these next updates with success and that it will succeed to install them
I also hope that i'm not going to have bugs now ! So ! Wait and see !
In any case , i want to thank all of the guys who have helped me !
Thanks a lot ! :wink:
Gradient Effect Plug-In
in Plugins - Publishing ONLY!
Posted
:shock: Hum , do you think it's really that ? I've just two or three , perhaps four, plugins that work wrong .The others seem to work fine like toon and drop shadow plugins . I think this is more my settings to make correctly when i use a plugin than my antivirus .
In any case , i've installed on my pc , Panda Titanium 2006 +antispyware+firewall , also installed spywareblaster and i launch spybot and adaware everyday .
