Tubular Tos
Posts
93 -
Joined
Last visited
Posts posted by Tubular Tos
:wink: Ok Illnab 1024 thanks i'm going to do this but when i uninstall Net framework through add/remove programs ... this is not really uninstall you know , the " Framework registry entries " stay ... Must i clean the registry with Regedit to remove all the framework registry entries ? I don't have framework 1.1 just framework 2 . Is this a reason of my problem ?
Thanks Illnab 1024 to try to speak French as i try to speak English ! This is " Où as tu telechargé paint .net et Net.framework ?
So , i got Paint .net from its website and Framework from Windows update . And my XP home edition is recognized by Microsoft , this is not a hacker software , if you see what i mean
Thanks to you too Bob but this is from this website that i got Paint.net . But when i start the "install" , it's stopped and it cannot finish the " install" and suddenly my pc slows down as if it searchs to do something or to connect to a website . Because when i want to close or restart windows i have a message that says : Net.broadcast event ... And i must to " click" : " to close now " And when my pc restart he works fine again
I think that i must have a problem with Windows installer too and now i can't install Framework updates from Windows update I think that some folders must be " corrupted " . So the best solution is to install a new clean Framework ... :oops: I think i use too much Easy cleaner and Regseeker and i must going to do something into my " registry " :oops:
Bob ? No error message ! :?
Please , Nobody can help me ? i have réinstall framework 2 but the 2.64 update doesn't work . It start the install but doen't go at the end and it makes my pc slow down ! Thanks again ! I have try all the solutions here but it doesn't work...
:wink: Thanks Bob ..if you want you can speak to me in french ..i'm French too and it's more easy to me to understand this " f " problem :oops:
I have used windows installer cleanup utility but the problem stays : Paint net folders are still there and the shortcut still works too... and the repair mode to Framework 2 doesn't help me . How can i do to uninstall paint net and Framework I would like to install them again but properly . Please ?
:? and so what can i do ?
:wink: i don't know what to do now !
Thanks to help me guys ! Bob i have just seen this topic thanks but this is not a 1704 error that i have , this cleanup utility seems to not work...
in the control panel : add/remove ...i want to remove Paint net and then i can see that it's removed but the folder's still here and the shortcut works again
when i check for the 2.64 update : file update check now ; it install the new version but nothing when i restart Paint net and it slow down my pc
but , and i think my problem is here, when i want to restart windows , i have an error message : net.Broadcast evnt window
Well now this is more complicated and i think i need some good help : roll :
Uninstall Framework ? and reinstall it ? :?
:x :? Please what's going on ? i can't uninstall 2.63 to reinstall it properly and when i check for the 2.64 update , this one start correctly but don't install it :? How can i do to have a log about this bug ? Please answer me i love this software and i need it . Thanks ? Must i reinstall Framework 2 ?
:wink: Gradient and glow work fine ... Distortion effects , photoflood , drop shadow and blurs don't work ....they start to work but at the end Paint .net is frozen if i " click " ok ...i think that i'm going to " reinstall " Paint.net and see what's happened
Yes of course , effects plugins are into the effects folder and my version is the 2.63 version ... I don't understand why two effects can work correctly and not the others... :?
:wink: Hi ! I'm French so my English is limited .... I'm new with Paint.net but i already love it .. I use it to make cover pictures for my music and my music website .. I have some problems .. when i download the plugins effects from here , i " unzip " them into the effects folder and i restart Paint.net but these effects don't work or they make Paint.net crashed or frozen . Can you tell me something about this ? Please help me ! There's just two effetcs that work correctly : Gradient and Glow . Thanks ! :wink:
Can't use the effects plugins from this site :-(
in Troubleshooting & Bug Reports
Posted
So no need too to remove manually the Microsoft.net folder into C:windows ?
