MeliRee Posted December 11, 2010 Share Posted December 11, 2010 I am creating a very simple cover for my book project using the front cover template from Lulu.com. Lulu's instructions are to: "lock" the template, and add a new layer within the bleed cut-off zones. I am having trouble doing so. First, I cannot lock the template layer. Secondly, when I add my image as a new layer, the template layer shrinks. When I try to resize the new image to 'match' the two layers, nothing happens. I need to be able to fit the new layer inside the template borders. How do I *lock the template layer? *resize my new image layer to fit within the template borders? Quote Link to comment Share on other sites More sharing options...
Rubrica Posted December 11, 2010 Share Posted December 11, 2010 I'm also using Lulu for my book publishing (what a lovely coincidence) and I'm just using trial and error; I now have a fully functional cover, exactly to my needs, and I didn't have to use the template at all. I'd recommend that you do the same, to be honest; it's nice and easy. Quote Link to comment Share on other sites More sharing options...
