RebarSpine Posted September 3 Share Posted September 3 Hello, thank you for taking time to read my post. I'm trying to add a logo over textured fabric and I can't seem to get the results I want. I want the logo to show the texture of the fabric it is on. I used the overlay blend option and it made the logo very dark. Additive make the blue outline too bright. Best idea to work around this? Quote Link to comment Share on other sites More sharing options...
Solution frio Posted September 3 Solution Share Posted September 3 How about using multiple copies of the layer set to different blend modes? I often use that as a lazy non-destructive way of spicing up layers. This is what you get if you duplicate the layer, set the bottom layer to normal blend 63/255 opacity, top layer overlay 255/255. 1 Quote Link to comment Share on other sites More sharing options...
RebarSpine Posted September 4 Author Share Posted September 4 Thank you! I messed around with the opacity before and it didn't look right. I didn't think taking the opacity down that low would work, but it turned out great. 1 Quote Link to comment Share on other sites More sharing options...
