t-legiaw Posted July 20, 2008 Share Posted July 20, 2008 I am owning a WIA compatible scanner. Everything works fine so far - e.g. I am able to aquire images from the scanner. But now I would like to "register" the Paint.NET application in a way that I am able to press the hardware button on the scanner. Paint.NET should then start automatically. There is a controlpanel entry called "scanners and cameras". I thought this would be the right place to add Paint.NET as a default application for "scan button" events. But unfortuneatly I am not getting a combo box or something like that to add a new application. Only "Photoshop Elements" is shown there. I even cannot add the normal paint program or something simular because there is no combox or textfield for entering a different application. Some suggestions where made by google posters to add a registry entry below HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\StillImage\Registered Applications. I have used an entry like C:\Program Files\Paint.NET\PaintDotNet.exe %1% %2%. Additionally I have deleted the existing entry for Photoshop Elements. But nothing changed. pressing the scan button always starts "Photoshop Elements" and not paint.net. So I assume that the HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\StillImage\Registered Applications is simply wrong. Any suggestions ? Quote Link to comment Share on other sites More sharing options...
MiguelPereira Posted July 21, 2008 Share Posted July 21, 2008 Try this right of the FAQ dunno if you've read this or if this will be of any help... Forget this I didn't read you post with enough attention, that's more advanced than the help I can provide... Quote [The stock on my sig is a photo I took not a render from Splatter] [My deviantART][My Gallery][My Space] Link to comment Share on other sites More sharing options...
HITMAN-X- Posted July 22, 2008 Share Posted July 22, 2008 So is this something your scanner was build to do as I never seen this before. Is it like a macro key or something ? Can your scanner do this with all other programs, like Paint ? Quote DEXTUT.COM Link to comment Share on other sites More sharing options...
